Call from CME to other PABX
Hi all,
My proplem is, when I call from my CME to an other PABX, the call was established successful and can hear the AA. But when I dial the extension, the call drop. Call flow as below:
1. Call to an other PABX number
2. Hear the AA voice
3. Dial extension number
4. Call drop
Below is my telephony-service configuration:
telephony-service
 sdspfarm units 10
 sdspfarm tag 1 confer2
 conference hardware
 max-ephones 58
 max-dn 300
 ip source-address 192.168.31.1 port 2000
 load 7942 SCCP42.9-3-1SR4-1S
 time-zone 41
 time-format 24
 max-conferences 22 gain -6
 call-forward pattern .T
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp May 07 2014 13:45:00
1 ACCEPTED SOLUTION
Hi Nguyen,You've not
Hi Nguyen,
You've not specified the dtmf-relay to be used for these dial-peers. It looks like you are using h323 as the protocol to send the call to the PABX? Is that right?
If so, add the 'dtmf-relay  h245-alphanumeric' command to the dial-peers that are pointing to the PABX and try the call again.
VIP Gold
did you apply dtmf relay to
did you apply dtmf relay to the dial peer which is pointing to pbx ?
Suresh
I think it is a pots dial
I think it is a pots dial-peer from cme to pabx
Hi Suresh,Thanks for your
Hi Suresh,
Thanks for your reply. Here is my dial-peer configure:
dial-peer voice 1 voip
 destination-pattern 4..
 session target ipv4:192.168.20.3
dial-peer voice 2 voip
 destination-pattern 9T
dial-peer voice 3 voip
 destination-pattern 111
dial-peer voice 40 voip
 destination-pattern 8T
Nguyen
Hi Nguyen,
It's worked, thank you very
It's worked, thank you very much, Sreekanth
Glad to know that! Thanks for
Glad to know that! Thanks for updating.
And dial-peer of gateway 192
And dial-peer of gateway 192.168.20.3
dial-peer voice 20 voip
 destination-pattern 2..
 session target ipv4:192.168.21.2
dial-peer voice 30 voip
 destination-pattern 3..
dial-peer voice 10 voip
 destination-pattern 1..
dial-peer voice 2 pots
 service aa
 port 0/1/1
Nguyen
97
