Call from number start with 8 &9 is routing out on VG.
When dialing to those numbers that starts with 8 and 9, the call is not reachable and show as engage from my side.
Numbers as follows:
03-8xxxxxxx
03-9xxxxxxx
Need expertise advise on this issue.
1 ACCEPTED SOLUTION
VIP Super Bronze
Rhuban,
Rhuban,
There are a few things wrong with your config...
1. You dont have an inbound voip dial-peer, hence your inbound call leg is matching on dial-peer 0 which by default uses G729, while your outbound call leg is matching on dial-peer 1 which is configured for g711. To resolve this do the ff:
dial-peer voice 10 voip
incoming called number .
dtmf-relay h24-alpha
codec g711ula
no vad
2. The second issue is that the outbound dial-peer that is matched does not have the right destination-pattern
dial-peer voice 1 voip
 destination-pattern 9888
The called number is 988869500
You need to change your dial-peer one to something like
 destination-pattern 9888.....
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
 Can you send a debug voip
Can you send a debug voip ccapi inout and debug isdn q931
Hi Ayodeji, Attached is the
Hi Ayodeji,
Attached is the debug for the number that dropping the call.
Number : 988869500
VIP Super Bronze
Rhuban,
Rhuban,
codec g711ula
no vad
Hi Ayodeji Thanks for your
Hi Ayodeji
Thanks for your prompt response. Really appreciate it. Will try as suggested and let u know the outcome.
82
