06-29-2009 10:03 AM - edited 03-15-2019 06:45 PM
I would like to run a report to see what phones are forwarded to where.
Possible?
06-29-2009 10:25 AM
Just by using a qry into the numplan table via CLI, no reporting on this via CCMadmin.
The fields are pretty self explanatory but you can look the data dictionary and just use the fields you're interested when running the qry.
java
if this helps, please rate
06-29-2009 10:29 AM
Do you have an example of the syntax for that command in CLI?
06-29-2009 10:37 AM
run sql
Then just write a qry in there
select * from numplan
If you want to fine tune this as i told you, either just look at the fields headers when you save this into a file or look at the data dictionary so you don't get all the info.
java
