Community Member
Call Fwd when not registered!!!
Hello all;
I am using CM 4.1(3) and I want to forward all voice calls to another extension or to voice mail when the phone is not registered with Callmanager, is it available?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Call Fwd when not registered!!!
Hi Ahmed,
This feature was not added until CCM 4.2(1) :(
Cisco Unified CallManager 4.2 introduces the Call Forward Unregistered (CFUR) feature as a way to reroute calls placed to a temporarily unregistered destination phone. The configuration of CFUR consists of two main elements:
Destination selection
When the DN is unregistered, calls can be rerouted to either of the following destinations:
Voicemail
Calls can be sent to voicemail by selecting the voicemail checkbox and configuring the CFUR calling search space to contain the partition of the voicemail pilot number.
A directory number used to reach the phone through the PSTN
From this SRND Guide;
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_2/srnd4_2/uc4_2/42dialpl.htm#wp1043810
Hope this helps!
Rob
1 REPLY
Hi Ahmed,
Voicemail
Hope this helps!
Rob
121
