Call go to one-way state after 45 - 60 seconds
I have the setup below:
Site A
CCM 5.1
IP Communicators
7940
All phones are in the device pool A
CODEC G.711
Site B
IP Communicators
7940
All phones are in the device pool B
CODEC G.711
Between sites the CODEC is G.729.
Almost all calls between any IP Communicators of any sites go to one-way state after 45 - 60 seconds.
The calls between IP Communicator and 7940 are working fine.
Does anyone can help me?
Rodrigo
1 REPLY
Green
Re: Call go to one-way state after 45 - 60 seconds
Which IPC version?
Can we get sniffer capture from each side to confirm we are sending|recieving RTP stream?
IP Communicators I assume are in data network so not sure if have some asymetric routing, FW etc etc
98
