Call Handler - Allow Transfers to #'s Not Associated
Is not working.   I want caller to be able to dial an extension from a call handler when that extension is not associated with an end user / Unity VM.  I have this working for another site but may have forgotten a step when setting up for this site.  At this point, I have checked the check box "Allow Transfers to Number Not Associated w/ Users or Call Handlers" under the Call Handler Edit Greeting.
Running CM and Unity Connection 8.5.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Hall of Fame Super Red
Re: Call Handler - Allow Transfers to #'s Not Associated
Hi Troy,
You will want to look at the Default System Transfer Restriction table
and compare the two CUC systems
Cheers!
Rob
Yes!  I forgot about the Restriction Tables.  I added a new one for the sites extension block and were working.  thanks!!
243
