Community Member
Call Handlers in Unity Connection
Hello
Somebody could help me to know the limit of the call handlers in an unity connection 8.0???....Additionly, in the market talk of multiple tenants or multiple-companies auto-attendant, is it the same as call handlers????
I would appreciate any help.
Thanks in advanced.
Alexis Munoz
1 REPLY
Re: Call Handlers in Unity Connection
AFAIK there is no hard number on the amount of call handlers you can have, only the HDD size would be a factor since all  require an entry in the DB.
And yes, usually when you mention AA and you use Unity or CUC that's the same as call handlers.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
180
