call history (CUE v2.3)
hii, i have a problem with the report of histroy call, it shows only the 20 recent calls, how can i configure the CUE to increase the size of the history call. Thanks
1 REPLY
Re: call history (CUE v2.3)
configure "DIAL-CONTROL-MIB" under global config on CME router it has 2 options one for number of hours you want to keep the log and the other is for size.
This will increase the CDR size in CME/CUE.
147
