Call history not displaying on IP phones, ex. missed calls
We set up a new site and now our IP phones which are 7941 are not showing the call history such as missed calls, received calls, and placed calls. We have call manager 8x. Also, the new site phones register to the subscriber in another site, we have a router and voice gateway at the new site.  Any suggestions what might be causing this is this on cucm side such as the device pool, or on the router and voice gateways configuration.
Thanks.
  • IP Telephony
Verify the phone configuration and the deivce pool assigned to the phones. Depending on the CUCM Group assigned to the device pool is what call manager it registers to. On the phone configuration you have the option of displaying the call history.
regards,
Yosh
HTH Regards, Yosh
What is the option called to display the call history on the phone?
hello Horacio,
I have seen a similar issue caused due to the firmware 8.2(2)  on 79xx phones.
Make sure the firmware version your on is the latest that compatible with your callmanger.
Hope this helps!
Karthik
Hall of Fame Super Silver
Horacio.
It's "Call Directory".  Are you saying you do not see any calls under any of the call direcories, i.e. placed/received/missed calls?  Or is the page not coming up at all?
Chris
Hi Chirs,
I do not see any new placed/recieved/missed calls after we setup the new site, it used to work at the other site.
I was looking for something else and ran into this post, so its late.
Verify your TFTP server information is either assigned by DHCP or that it's statically set on the phone (if not provided by DHCP).
I had the exact same issue.  You can have a phone set to automatically obtain the all the IP settings, move it to another subnet that does not have the TFTP server option on it and the phone will still come up, but the missed/recieved call lists stay empty.
Perfect answer for me.Turns
Turns out the DHCP server was changed the smae bank holiday weekend the office moved its comms room and the same weekend the clocks changed!!!!
Option 66 on Infoblox was missing from the new server.
Thanks a lot.
Re: Call history not displaying on IP phones, ex. missed calls
I'd think this is more to do with URL directory not working for the remote site. Do you have a firewall which blocks http/https traffic or dns issue between the remote site and cucm. If directories URL points to dns name in enterprise parameters, then the phone needs to be able to resolve it
23037
