11-09-2007 05:33 AM - edited 03-15-2019 07:08 AM
Is there a way to enable an audible beep when a call is holding on the line? Particluarly with a shared line appearance. I am using a 7931 phone and a 2811 ISR. I can find ways to put in too much information when searching for this kind of information and am hoping someone remembers a link to where they did this.
Much thanks,
Jon
Solved! Go to Solution.
11-09-2007 05:40 AM
Hi Jon,
This feature is available :)
On-Hold Indicator
On-hold indicator is an optional feature that generates a ring burst on idle IP phones that have placed a call on hold. An option is available to generate call-waiting beeps for occupied phones that have placed calls on hold. This feature is disabled by default.
LED color display for hold state, also known as I-Hold, is supported in Cisco Unified CME 4.0(2) and later versions. The I-Hold feature provides a visual indicator for distinguishing a local hold from a remote hold on shared lines on supported phones, such as the Cisco Unified IP Phone 7931G. This feature requires no additional configuration.
SCCP: Enabling On-Hold Indicator
The Call Hold feature is available by default. To define an audible indicator as a reminder that a call is waiting on hold, perform the following steps.
SUMMARY STEPS
1. enable
2. configure terminal
3. ephone-dn dn-tag [dual-line]
4. hold-alert timeout {idle | originator | shared}
5. end
From this good doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmering.html#wp1013688
Hope this helps!
Rob
11-09-2007 05:40 AM
Hi Jon,
On-Hold Indicator
SUMMARY STEPS
1. enable
5. end
From this good doc;
Hope this helps!
Rob
