call is jumping from headset to speaker
snier
Hi all,
at one phone I have the situation that a call is connected to a headset and while the call it jumps from headset to the speaker. the connection is going on.
Thanks and regards
Stephan
have anyone an idea whats happened?
Rob Huffman
Hi Stephan,
This is most likely a Phone Firmware issue. There were many Bugs associated with the 7.x firmware that caused this exact type of problem. We had users that experienced many odd handset/speakerphone/headset issues. I am not sure what model of phone you are using but there is a new phone firmware 8.2(1) that seems to have solved these problems.
Hope this helps!
Rob
Hello Rob,
thanks for that info. The phone type is 7940 with a Release 8.0.4 .
I thinks that I downloaded it some time ago.
Regards Stephan
