call issue in VG204
Hi all
I deploy a VG204 in our company, a analog phone connect to VG204. I test both inbound and outbound calls both working well. But we find one problem:
when i made a call from IP Phone to analog phone, if I disconnect from IP Phone, the analog phone can't disconnect, not busy tone from analog phone, instead of is a long tone, just like off hook, after waiting 8 second, i can hear busy tone.
I use SCCP protocol to register VG204 to CUCM and CUCM version is 6.15.
below is my VG204 configuration:
no aaa new-model
clock timezone GMT 8
ip source-route
ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp
voice-card 0
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.212.132.100 255.255.254.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.1.1.1!
no ip http server
control-plane
voice-port 0/0
timeouts ringing infinity
caller-id enable
voice-port 0/1
voice-port 0/2
voice-port 0/3
ccm-manager fax protocol cisco
sccp local FastEthernet0/0
sccp ccm 10.1.1.1 identifier 1 version 6.0
sccp ccm 10.1.1.2 identifier 2 version 6.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
switchback method graceful
dial-peer voice 1 pots
service stcapp
port 0/0
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
Need your advice for this case, thanks very much.
Green
call issue in VG204
Can you try adding
service stcapp
tone dialtone remote-onhook
port 0/0
Alex
Regards, Alex. Please rate useful posts.
call issue in VG204
The command tone dialtone remote-onhook like a default command under the  dial-peer voice, and try this command, the problem still not resloved.
Silver
call issue in VG204
Hello!
In the configuration i can see you have to call manager servers.
Please confirm.
Check in the device pool of the vg204, if in the ccm group you have given priority to 10.1.1.1 or not.
The first server in the ccm group applied on the vg204 should be
10.1.1.1, and second 10.1.1.2
So basically the priority given on the vg204 for cucm servers should match the ones in the ccm group.
Then do a no sccp and then sccp.
See if that resolves the issue.
Kunal
749
