Call legs with different codecs
The situation is like this. I've got one router (HQ-1) which has one C7965G IP phone registered. This router is connected over E1 line to another router (PSTN) which simulates PSTN-like connectivity. There's also another C7965G IP phone registered to the PSTN router.
I've configured one of the phones to use iLBC as prefered codec. So it works, but when I use these two commands:
HQ-1#show voice call status
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0x3C       1285 0x4B1893A8 50/0/1.0                 112        ilbc     20005/112
0x3D       1285 0x49C710B4 0/2/0:15.8       0/1:1  *112        ilbc      112/20005
1 active call found
PSTN#show voice call status
0xF3       1222 0x488478D0 0/0/0:15.8       0/1:1   19016      g711ulaw 1120/20006
0xF4       1222 0x48844C78 50/0/6.0                *19016      g711ulaw  20006/1120
1 active call found
So it appears to me that I've got one input call leg (from the 7965G phone to the HQ-1 router) and another outgoing call leg (from the HQ-1 router to the PSTN router over the E1 line). Which is perfectly fine.
What confuses me is the second output from the PSTN router. Because it shows one input call leg that is using g711 and another call leg to the 7965G phone.
From my understanding the outgoing call leg from HQ-1 to PSTN should be the input call leg to the PSTN router. Shouldn't it use than the same codec, iLBC in this case? In that case where the transcoding takes place?
Am I interpreting the outputs correctly?
Here're also the outputs from "show voice dsp"
HQ-1# show voice dsp
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
edsp 0001 01 ilbc      0.1 busy  50/0/1.1
edsp 0002 02 ilbc      0.1 IDLE  50/0/1.2
edsp 0003 01 g711ulaw  0.1 IDLE  50/0/2.1
edsp 0004 02 g729r8 p  0.1 IDLE  50/0/2.2
----------------------------FLEX VOICE CARD 0 -----------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
C5510  001 01 ilbc          27.3.3 busy  idle      0  0 0/2/0:15  08    0  78343/78355
                           *DSP SIGNALING CHANNELS*
------------------------END OF FLEX VOICE CARD 0 ----------------------------
PSTN#show voice dsp
edsp 0001 01 g711ulaw  0.1 IDLE  50/0/1.1
edsp 0002 02 g711ulaw  0.1 IDLE  50/0/1.2
edsp 0005 01 g711ulaw  0.1 IDLE  50/0/3.1
edsp 0006 02 g729r8 p  0.1 IDLE  50/0/3.2
edsp 0007 01 g711ulaw  0.1 IDLE  50/0/4.1
edsp 0008 02 g729r8 p  0.1 IDLE  50/0/4.2
edsp 0009 01 g711ulaw  0.1 IDLE  50/0/5.1
edsp 0010 02 g729r8 p  0.1 IDLE  50/0/5.2
edsp 0011 01 g711ulaw  0.1 busy  50/0/6.1
edsp 0012 02 g729r8 p  0.1 IDLE  50/0/6.2
edsp 0013 01 g711ulaw  0.1 IDLE  50/0/7.1
edsp 0014 02 g711ulaw  0.1 IDLE  50/0/7.2
edsp 0015 01 g711ulaw  0.1 IDLE  50/0/8.1
edsp 0016 02 g729r8 p  0.1 IDLE  50/0/8.2
edsp 0017 01 g711ulaw  0.1 IDLE  50/0/9.1
edsp 0018 02 g729r8 p  0.1 IDLE  50/0/9.2
edsp 0019 01 g711ulaw  0.1 IDLE  50/0/10.1
edsp 0020 02 g729r8 p  0.1 IDLE  50/0/10.2
edsp 0021 01 g711ulaw  0.1 IDLE  50/0/11.1
edsp 0022 02 g729r8 p  0.1 IDLE  50/0/11.2
edsp 0023 01 g711ulaw  0.1 IDLE  50/0/12.1
edsp 0024 02 g711ulaw  0.1 IDLE  50/0/12.2
C5510  001 01 g711ulaw      27.3.3 busy  idle      0  0 0/0/0:15  08    0  86893/86913
Everyone's tags (5)
Hall of Fame Super Gold
First of all with CME you should normally use G.711. You can explore the use of other codecs when you have the real necessity.
Second, transcoding doesn't happen unless you configure it.
Dear Paolo,
I'm not aware of any restrictions as far as the codecs are concernd when CME is used.
Transcoding isn't configured on neither of the routers in this setup.
What I'm puzzled with in this output is that it appears to me that in one direction of the E1 line (from HQ-1 to PSTN) the codec used is iLBC, and on the reverse direction (from PSTN to HQ-1) it's G.711. This doesn't make any sense to me? And when E1 line is used, shouldn't the codec always be G.711uLaw?
So maybe I'm not interpreting the outputs correctly. That's why I started this discussion...
591
