Call Management
(1)Does callmanager has the capability of limiting the maximum number of hours that a user can make outbound call (PSTN) per month. (2)Does callmanager has the capability of limiting the duration of an initiated call to a defined period of time(eg 3 minutes). (3)If these are possible, I will appreciate if I can have the URL to get the materials to read up.
1 REPLY
Hall of Fame Super Red
Re: Call Management
Hi Christian,
This setting is also applied to all Incoming and Outgoing CUCM calls;
Clusterwide Parameters (Feature - General)
Maximum Call Duration Timer :
This parameter specifies the minutes that a call can remain active before Cisco CallManager clears it. A value of zero disables the timer.
This is a required field.
Default: 720.
Unit: min.
Minimum: 0.
Maximum: 35791.
Hope this helps!
Rob
106
