CAll Manager 4.1.3 SQL Table information?
Can someone tell me what DB the "External phone number mask" is stored in?
I have an issue were I need to verify all our DN's (4 different exchanges totalling over 600 DN's) externl phone number mask.
I am not sure how to do this. I was thinking if I could open SQL enterprise manager and find what DB and table its stored in. I can just do a mass search. I then can compare that list to the spreadsheet I have. My problem is I do not know where to look in the call manager SQL tables.
Hall of Fame Super Red
Re: CAll Manager 4.1.3 SQL Table information?
can't recall exactly but i believe it was either on Device or in DNorPattern table
java
if this helps, please rate
java
www.cisco.com/go/pdi
Here is a query that may help you. This will display all Cisco Phones (if you want to view everything, remove 'device.name like 'SEP%' and').
Use Query Analyzer and run it against the CCM database.
select device.name as device,
device.description,
numplanindex as Line,
dnorpattern as DN,
E164Mask
from device,devicenumplanmap,numplan
where device.name like 'SEP%'
and device.pkid = devicenumplanmap.fkdevice
and devicenumplanmap.fknumplan = numplan.pkid
Please rate if helpful
366
