Call Manager 5.0 License
I have 60 DLUs not used (for Cisco Devices), and now I need install a Third-Party device.
Need I buy a Third-Party license? Or can I use the my licenses?
1 ACCEPTED SOLUTION
Re: Call Manager 5.0 License
what device are you planning to install???
if it's going to be a sip phone you can use your licenses, if it's going to be h323 no license is required
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
Thanks.
I will instal a sip device.
Have you a link with this information (about license)?
Best Regards.
simply go to the license calculator on your server and you will see both sip devices you can use, each one requires X amount of DLUs
java
java
Yes, I made this.
thanks again.
121
