Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Anonymous
N/A
Call Manager 5.1.2.3 upgrade to 8.6
My customer already ordered the new server (MCS7835I3-K9-CMD3A) for running Call Manager v8.6.
In the existing environment, the Call Manager is running version 5.1.2.3000.002.
I will use the new server to replace the existing server.
However, may I know the procedure for export the existing version database and convert/Import to v8.6?
Is Cisco have any tools for converting the database?
Thanks and Regards,
Ivan
The only way to upgrade the database to make it usable with 8.6 is to upgrade to 8.6.  From 5.1.2 and upgrade would require multiple upgrade steps, probably something like upgrading to 6.1.3 then to 7.1.5 first and then upgrading to 8.6.  You can find the upgrade paths from this document:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html.  One other thing to be aware of is to make sure your current server model supports these upgrade stepped versions which can be found here:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html.
Hi Ivan,
1. Create a test cluster with 5.1.2 installed on all the new servers
with backup restored on them from the production server.
2. As the MAC address of PUB server would be different from the previous one, so, get all
phone, node and software feature licenses from the licensing team for new PUB server with
call manager 5.1.2 version.
3. Now, as per the upgrade path (depends on the version you are ultimately trying to
upgrade to)you can upgrade to the nest version and then to the final version.
4. Please get software feature license for call manager version 8 for new Publisher
server.
5. Software feature license is required every time you change the call manager version
train. i.e move from one version to a higher version.
6.Then finally replace the old cluster with the test cluster during off production hours.
Following are some the upgrade paths to go to 8.6.X from 5.1.2, which I
could find:
5.1(2)>>6.1(3b)>>7.1(5)>>8.6(1a)
5.1(2)>>6.1(3b)>>7.1(5)>>8.6(2)
5.1(2)>>6.1(3b)>>7.1(5)>>8.6(2a)
5.1(2)>>6.1(3b)>>8.0(3a)SU2>>8.6(1a)
5.1(2)>>6.1(3b)>>8.0(3a)SU2>>8.6(2)
5.1(2)>>6.1(3b)>>8.0(3a)SU2>>8.6(2a)
5.1(2)>>6.1(3b)>>8.0(3)>>8.6(1a)
5.1(2)>>6.1(3b)>>8.0(3)>>8.6(2)
5.1(2)>>6.1(3b)>>8.0(3)>>8.6(2a)
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
Anonymous
N/A
Thanks for your graet procedure.
May I know which upgrade path is the best or suggested path after upgrade from 6.1(3b)?
Thanks.
Hi Mei Ching Wong,
I would prefer the less number of intermediate upgrades to reach the 8.6.
Hope it helps.
Please dont forgte to rate the helpful posts by clicking on the stars below each of the right answers .
Anand
1433
