Call manager 5 in cisco phone
Murali Dharan
Hello All,
Maximum 3 call managers can be added in CM group and one SRST reference. So totally 4 CM servers but why we have CM server 5 in all cisco phones under network configuration.
-Murali
Chris Deren
perhaps the plan at one point was to support more, and nobody ever bothered to adjust the page. In either case 3 +1 as you state is the max.
HTH,
Chris
AFAIK that one should be the TFTP server, so, assuming they're alls separate servers, 3 CUCM, TFTP, SRST
java
if this helps, please rate
