Call Manager 6.0 LDAP Sync Issue
I have call manager 6.0 synchronise successfully with an active directory server via LDAP. However when the users are imported successfully via LDAP, the password and pin are not disclosed? I presume the password would be the login credentials of the user I have created in AD however as I login to the ccmuser page it tells me that the credentials are wrong. I use the UDP function as well so the PIN appears to be unknown as well? Any ideas to this?
Any feedback will be of great help. Let me know if you guys need any other info from me?
ST
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Call Manager 6.0 LDAP Sync Issue
Just
having issues with the password. Do I need like a LDAP browser installed
 on my AD server?
No. There are a few basics I can think of:
  • Make sure you are not running on 2000 domain functional level. I think that has been dropped.
  • Check to ensure that your authentication search context covers the end user object you are trying to bind.
  • Check your LDAP servers shown in the authentication page and ensure the port is correct. 389 if not a GC; 3268 if it is. Leave SSL off until you get this working.
VIP Super Bronze
Are you only synchronizing end user objects; or, are you synchronizing and performing LDAP Authentication? These are two separate configuration items in the UCM Administation GUI. If the Password field on the End User Configuration page is enabled, you are not performing LDAP-based authentication.
Ensure that the user has been added to the Standard CCM End Users group. This is a required group membership for access to the /ccmuser webapp.
PINs are not synchronized with LDAP at all. You will need to set the value on the End User Configuration Page. Also ensure that the password is not set to require the user to change it at next login. If this is the case, Extension Mobility will fail to login with an error.
ST -> I am synchronising with LDAP Authentication as well. Therefore when I click on the End User Configuration Page the password field is not change-able.
ST -> Yes I did enable End User group for the user in order to login as well.
ST -> In regards to the PIN, im sure that i can update a bulk of entries using the BAT tool. Which is not a problem.
Just having issues with the password. Do I need like a LDAP browser installed on my AD server?
VIP Super Bronze
Just
 on my AD server?
Thanks Jonathan, your the CHAMP!
I've raised the domain functional level to Windows 2003 mode and try again; it works like charm!!
Simply Brilliant. Thanks for your help
ST
1462
