Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Call manager 6.0
I have a call manager 4.2 installed in my office and i want to upgrade to ccm 6.0 from the disc.Can somebody give me the name of the patch needed to do the upgrade?
Re: Call manager 6.0
the part numbers are on this page:
Cisco Unified Communications Manager Version 6.0
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/product_data_sheet0900aecd805e323f.html
load the DVD and the install will install automatically, choose upgrade when prompted and point to the DMA file.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Do you have smartnet ? In that case you can order disks via Product Upgrade tool.
No i don t have smartnet.
You will have to order the upgrade part numbers as mentioned by the previous poster.
Thanks a lot.
108
