Community Member
Call Manager 6 CDR CSV file
Call manager 6 is outputing the CDR CSV file in form of following:
1)cdr_StandAloneCluster_02_20080201000000_00001.txt
however my Call Accounting software need the CDR CSV file to be in the following format:
2)cdr_StandAloneCluster_02_20070101000000_00001.csv
Please see attached files. Cisco CM 6 has to create the CSV files with quotes around the fields for the Call Accounting software to process the files. How do i get CM 6 to format the CSV file the way i have it?
1 REPLY
Community Member
Re: Call Manager 6 CDR CSV file
Hi level 3RD
this is Fabian from Innovative, am not sure the information that u collected as yet but this is what i found so for. see link below
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_0_1/car/carexprt.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_0_1/car/car-cm.pdf
also when u exporting check to see if u get an option to change the file type. keep me posted
good luck
killy
1061
