Call Manager 6.X Database format
Hello
is there somebody who know if there is a document (and where i can find it describing the format database in CM 6.X like there was fir preivous version?
Tanks in advance
Regards.
Florence
Re: Call Manager 6.X Database format
exactly what are you trying to do???
if you switch partitions to previous version you will get the old DB.
we have the data dictionary that describes the layout of the DB but we do NOT support making changes directly to the DB.
java
if this helps, please rate
java
www.cisco.com/go/pdi
At this time we are doing nothing!! and this is not our attention to change anything in the database!!.
What we want is to be able to extract informations on call in order to build statitistics.
Is this possible?
Rgds
Florence
yes, two ways. configure a billing server and send CDR data to another server for processing or via SOAP
java
java
Is not a word missing in your answer?:
"and send CDR data to another server for processing or via SOAP"?
Rgds
Florence
no, no missing words, you can configure a billing server to send the CDR data via SFTP, or use SOAP
java
java
166
