11-26-2007 01:12 AM - edited 03-15-2019 07:25 AM
Can someone help me out with 2 queries:
1-> What are the improvements in CCM 6 over CCM 5, I mean features & all.
2-> When was CCM 6 released on the market ? Approx 3-6 months back??
11-26-2007 01:44 AM
The biggest advantage of CUCM 6.x is that Mobility Manager is now integrated. Refer to this document for other features:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_data_sheet0900aecd805e323f.html
Not sure if CUCM 6.x is still on new product hold but you're best to wait for 6.1 to be released which should be the first quarter of 2008.
11-26-2007 06:46 AM
Thanks, really appreciate your help.
11-26-2007 09:20 AM
Is there any gotcha's when upgrading to CUCM 6.0?? Can someone who has it running in a production enviroment please comment as to what you think about this version. We're looking to upgrade soon, Would like to know if there was a big difference in administration
11-26-2007 09:56 AM
Besides the built in mobility it also has a ton of new features plus the CM 4.2 features that are not available in 5.X.
As to the upgrade make sure you obtain the new CUCM 6.0 license key as well as make sure the hardware meets the requirements.
Chris
11-26-2007 05:30 PM
I am going to attempt again to upgrade tonight. I had a very frustrating day on Friday trying the upgrade. I turns out that all my issue were with the CDR database. I highly recommend you purge the CDR database before you run DMA. It took more than 8 hrs to upgrade from 4.2(3) with a large CDR database. The more you can clean up CDR the better. I am going to be running 6.0.1.2116-1. I will post later when we are running in productions.
Jim
