Call Manager 6x Call Routing
whats the best way to route
calls on-net between gateways, on
1 cluster.
Re: Call Manager 6x Call Routing
By default calls that arrive thru gateways are classified as off-net so you would need to clarify and provide an example.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
currently i'm routing calls with translation patterns.
i have multiple remote offices, and to place calls
to each other i configure a translation pattern in location A and
place the css of the location B. All of my locations are connected
via our Wan. sorry if im not clear...new to this stuff.
VIP Super Bronze
If I understand you properly, you appear to be asking what the best dialplan design is within UCM for dialing between on-net sites. This answer has a whole chapter dedicated to it in the UCM SRND; however, if I make a long list of assumptions about your environment:
  • Baring number overlap scenarios, each user's DN typically exists in a single partition such as Enterprise_PT.
  • When user A calls user B's extension the device-level CSS of user A includes the single Enterprise_PT. No translation is needed.
  • IF you have numbering overlap and need to use inter-site access codes (also explained in the SRND), then the DNs are configured in their fully qualified form and a single per-site translation pattern exists to expand intra-site abbreviated dialing to the full form.
    Example: 85551234 is the DN configured in UCM. Users are taught that 8 is the inter-site access code, 555 is the site code for site B, and 1234 is the user's four-digit extension at site B. Others at site B would dial 1234 and UCM would translate the intra-site call into 85551234.
Cisco Unified Communications System 8.x SRND - Dial Plan would be the best place to start here.
Please remember to rate helpful responses and identify helpful or
330
