FYI: DCD was only used in Windows versions, Linux appliances hold all that in the Informix DB
You cannot sync without integrating, if the user ID attribute you created your users with, matches the same attribute you're using to sync with AD they will be retained. Otherwise the garbage disposal will delete them.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
