12-16-2011 02:15 PM - edited 03-16-2019 08:34 AM
I am standing up call manager 8.6.2 in our lab VM environment for a dry run of the upgrade process. I've been trying to research how to get my data from 7x to 8.x (phones, route patterns, gateways, etc). I know from 4.x to 7.x we had a vendor do that job and they used DMA I believe. But I'm doing the job this time around and going from physical hardware to UCS platform for virtualization.
Is it a simple restore of a 7.x backup to the 8.x system or is there some utility? Not having much luck with the google machine searches
12-16-2011 03:59 PM
Hello:
There are no utilities similar to DMA. Only option is to use DRS backup and restore procedure.
12-16-2011 04:07 PM
Only supported method is to upgrade existing evironment to version 8.X, take DRS backup. install the same version on UCS and perform restore from the backup.
Unsupported method, which I have had good sucess with is to install version 7.1 on UCS and restore from current backup, and then upgrade to version 8.6.
HTH,
Chris
