Call manager 7.1.5 integration with Unity connection 9
I am in the process of upgrading my UC environment and instead of labbing a unity 7 (windows) I did a an export from unity to unity connection.  I am now trying to integrate CUCM 7 with unity connection 9.  I am having issues with the Voicemail ports.  The device name prefix needs to have a VI at the end of the name for unity connection 9 and nothing else but CUCM needs a VIn where "n" represents a number.  In order for them to work they need to match.
Someone let me know.  Thanks for your help.
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Earl,
Just the "prefix" part needs to match so for example
in CUCM the ports might be;
CiscoUM1-VIx (but connection doesn't care about x where x=port#)
so in Connection you just need to set the prefix;
Device Name Prefix = CiscoUM1-VI
Cheers!
Rob
"Why do the best things always disappear "
- The Band
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Hi Earl,
Cheers!
Rob
- The Band
Thanks man..I found that out 45 mins later.. lol
Silver
Hello Earl,
Here are some screenshots on both perspectives:
1. When you perform the voicemail configuration on the CUCM you would go to Advanced Features>Voice Mail> Cisco Voicemail Port Wizard, you will get the two following screens:
First one will let you decide if whether you want to add to an existing one or create a new one:
Afterwards you will have to put in the prefix, in this example we used CCIE-1-VI:
Now on the CUC perspective:
Best Regards,
-Peck, David Rojas
105
