Call manager and analog pbx
I have an old analog pbx
I am installing a cucm 8.0
I am installing one voice gateway CME on cisco 1900 router with fxs and fxo card
Physical conexion
Analog phone - Old analog pbx  - fxs card on cisco 1900 CME - CUCM - switch cisco  -  IP phone
Is it possible for analog phone to comunicate with ip phone , and ip phone to comunicate with analog phone
if yes, How should i configure the CME cisco 1900 and the CUCM
Thanks in advance for your help
3 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
You will need to integrate the PBXes, but you cannot integrated with FXS cards on both sides, you will need FXO side on one side, i.e. Cisco.  Then configure the old PBX to route the numbers you want to the FXS line (if you cam have more than one) and similarly configure the GW and CUCM to route the calls appropriately.
HTH,
Chris
Green
1) Did you test if you can put the original incoming call on hold wait say 3 secs then resume.
If that works you shouldn't need the MTP
2) Is the gateway H323 , SIP or MGCP ?
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
VIP Super Bronze
The cucm software MTP is availabe by default when you enable the "Cisco IP Voice Media Streaming App" service. So you need to enable the service to get MTP resource on CUCM.
You then need to go to "Media resources>media resource group" in cucm. You can then add a new MRG of Add media resources to an existing group. In the media reosurces selection you will see something like MTP_1, MTP_2. Assign this to the MRG. use the same media resources tab, to assign MRG to MRGL. On the gateway page you will see where to assign a MRGL to the gateway
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
In theory, this should work fine. As to how to do it: That's not a simple answer ! (Especially as I don't do CME. Nor have you said how you're connecting the CME with CUCM)
One small question, though: What's the need for the CME ?
GTG
Please rate all helpful posts.
Green
Hi Guys,
Step back a wee bit.
Cisco 19XX routers can not support FXS/FXO cards they have no DSP slots.
You will need to consider 28/38XX or 29/39XX series routers.
Have a look at this link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme90spc.html
At the bottom under the phones you will see the supported routers and recommended memory etc.
Alex.
VIP Super Bronze
Re: Call manager and analog pbx
Just to add to the excellent post by Alex (+5), here is an overview of what the ISR G2 routers do and dont do. The 1900 ISR routers do not do any form of unified communications, no CME, no PVDMS, no fxs/fxo ports
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c45_556315.pdf
Hi all
You are right it is the 2900 router use as voice gateway
I apoligize for the mistake
Here the physical connection:
Old Analog PBX  -  FXS port of cisco 2900 voice gateway - cisco switch - CCUM
I already added PVDM and FXS 4 port in the cisco 2900 voice gateway
Is it possible for analog phone(connected on the Analog pbx) to comunicate with cisco ip phone (connected on the switch), and ip phone to comunicate with analog phone
If yes, How should I configure the cisco 2900 voice gateway
How should I configure the CUCM
HTH,
Chris
Hi made installation as you suggested and it work,  but there is some few problem
From CUCM to PBX It is OK , cisco phone user XXXXX can join old analog phone directly XXX
But from Old PBX to CUCM, user cannot dial cucm user directly : PBX user (for exemple XX4) user should dial the extension line (the for extension have been group in one line) connected to the FXO port
Then the call is forwaded to cico phone number XXXX1 (all incoming call on FXO card are automaticaly forwaded to cisco phone XXXX1) and user XXXX1 should forward call to appropried CUCM user (for exemple XXXX5)
But when the call is forwaded to appropried CUCM user, communication cannot be establiched betwen PBX user XX4  and appropried CUCM user XXXX5
How can I resolv this problem
Thanks in advance
Green
May be you FXO gateway needs MTP.
Can you call as usual from old PBX to CUCM
Answer call and speak OK ?
Then put the call on hold from the CUCM phone
Does the call drop.
If yes then you need to check the MTP box on the gateway config page in CUCM Admin.
Alex.
Thanks for your answer
Yes when I call as usual from old PBX to CUCM answer call and speak is OK
But when I transfer the call to approprited final user on cisco cucm phone, he answer but he cannot speak with old pbx user phone
Where should I check the MTP box, I found is without success
I need to precise that I have 4 FXO card on the cisco 2900 gateway,  one is connected on the old pbx as you suggested and 3 are connected on public PSTN line
hope that MTP box on the gateway will not affect PSTN call
I am not sure why you'd want to keep your pbx at all. It's a dead system. My advice is do away with it and order some VG224 Cisco analog gateways. They connect with CUCM, you just configure it under device and then gateway. It is reliable and works really well with analog phones, or faxes, or alarm circuits. Each gateway can support 25 analog lines.
Bitter experience tells me that VoIP systems aren't perfect for every analogue device:
- Super G3 Fax machines. (Failing to negotiate down to normal G3 speeds)
- Computer Modems. (Nothing more than about 22Kb/s)
- Alarm systems.
- Door entry systems.
Have all given me problems and require analogue exchange lines because they don't work on VoIP systems.
GTG
PS VG224s have 24 ports, not 25
Green
Alex.
Yes, that's right it does only support 24, my bad.
regards
1. I put the call on hold but when I tried to resume I did not get voice on old pbx phone again
2. the gateway is H323
Hi all
Please  help
I still have the same problem
Thanks in advance for your answer
VIP Super Bronze
Looks like you need MTP. You need to enable MTP required on the h323 gateway in cucm. Go to device>gateway, select the h323 gateway and scroll down you will see under signalling port "media termination point required" check the box next to it.
Now you need to ensure that there is an MTP available in the MRGL of the gateway. You can use the cucm software MTP. Assign it to the MRG of the gateway and then assign the MRG to the MRGL. Then assign the MRGL to the gateway
Thanks I will try it
But in dont how to do this part
I am new on CUCM
VIP Super Bronze
It work
Thanks for your help
I have a problem with call between Old PABX and CUCM
when I made a call, it work,  then at  the  end of call I hangs up but I observ in that the calls remain active in the voice gateway
see below
Voice-GW#show voice call st
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0x6        11E7 0x29742C9C 0/2/0            No DSP *5000       None      500/0
0x14       11F8 0x29745FC8 0/2/2            No DSP *5000       None      500/0
0x1C       1203 0x2974762C 0/2/3            No DSP *5000       None      500/0
3 active calls found
Voice-GW#
Whuy the call remain active after hangs up ?
How can I do to remove call on active call list after hangs up ?
Hall of Fame Super Gold
Please open new thread for new problems, including complete call flow, configuration, and traces.
1665
