Community Member
Call Manager and Unity 8.6.2 with AD 2012 R2
Just wondering if anyone has had any success integrating Call Manager and Unity connection 8.6.2 with an LDAP directory on a Microsoft Server running 2012 R2.  On the only document posted (linked below) 2012 is not even listed.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/directry.html#wp1097641
Todd
1 ACCEPTED SOLUTION
Because you need 10.X for it
Because you need 10.X for it to be supported.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmsys/CUCM_BK_SE5FCFB6_00_cucm-system-guide-100/CUCM_BK_SE5FCFB6_00_cucm-system-guide-100_chapter_010011.html
It *might* work, but you'll lose all Cisco support if anything that relates to LDAP happens to you.
java
if this helps, please rate
www.cisco.com/go/pdi
java
Community Member
Thanks for the quick response
Thanks for the quick response Jaime.
I understand that an AD 2012 server can function as an AD 2008 server.  Have you had any experience with this?  I would think this would be compatible but I don't want to assume.  We're not going to be doing anything complicated with the integration, no forest functionality in use.
58
