Call Manager and Unity Upgrades. Check my math please
                   All,
running CM 7.1(5) on an MCS 7835-H2 and Unity Connection 7.1(5) on an MCS 7825-H3.  I want to do an in place upgrade to 9.x  for both.  According to what I am seeing this should be possible as a a straight jump correct?
Thanks in advance. Replies rated.
1 REPLY
EXACTLY which model???
All the way up to IPC1 for example, just saying what familiy your server is doesn't work.
You can check by yourself on this links whether they're supported or not, most likely a HW reconfiguration might be required (more RAM and/or HDD)
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/9x/supported_platforms/9xcucspl.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
111
