Community Member
Call Manager AutoAttend
Currently Being Moderated
Call Manager Express
I am in the process of setting up an AutoAttend. When i place a call from internal to our AA (6001). I am able to navagate the menu and it works perfectly fine.
When i call into the AA from an external number, i am able to navagate the menu however there is a 15-20 sec delay after i type a menu option.
This does not exists when i dial internally..
debug:
Dec 13 14:23:07.575: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=4122194514, Called Number=4122194514, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4122194514
Dec 13 14:23:07.575: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=4122194514, Expanded String=4122194514, Calling Number=4122194514T
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Dec 13 14:23:07.575: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=2 Is Matched
   Result=Success(0) after DP_MATCH_DEST
Dec 13 14:23:07.579: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=2
Dec 13 14:23:07.579: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=7248806682, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Match Rule=DP_MATCH_ANSWER; Calling Number=7248806682
Dec 13 14:23:07.579: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Dec 13 14:23:07.579: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=7248806682T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
Dec 13 14:23:07.579: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=7248806682
Dec 13 14:23:07.579: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=2 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2
Dec 13 14:23:07.579: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
   Result=-1
Dec 13 14:23:07.583: //-1/EBBF6FC38182/DPM/dpAssociateIncomingPeerCore:
   Calling Number=7248806682, Called Number=4122194514, Voice-Interface=0x0,
   Match Rule=DP_MATCH_REQUEST_URI; URI=sip:4122194514@10.209.3.40:5060;transport=udp
Dec 13 14:23:07.583: //-1/EBBF6FC38182/DPM/dpMatchPeertype:
Dec 13 14:23:07.583: //-1/EBBF6FC38182/DPM/dpMatchCore:
   Result=-1
Dec 13 14:23:07.583: //-1/EBBF6FC38182/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_TO_URI; URI=sip:4122194514@67.231.4.93
   Result=-1
   Match Rule=DP_MATCH_FROM_URI; URI=sip:7248806682@192.168.27.76;isup-oli=61
   Result=-1
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=4122194514
Dec 13 14:23:07.583: //-1/EBBF6FC38182/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=13 Is Matched
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=13
Dec 13 14:23:07.583: //-1/EBBF6FC38182/DPM/dpAssociateIncomingPeerSPI:exit@6170
Dec 13 14:23:07.591: //-1/EBBF6FC38182/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6001, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=6001
Dec 13 14:23:07.591: //-1/EBBF6FC38182/DPM/dpMatchCore:
   Dial String=6001, Expanded String=6001, Calling Number=
Dec 13 14:23:07.591: //-1/EBBF6FC38182/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=6001 Is Matched
Dec 13 14:23:07.591: //-1/EBBF6FC38182/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=6001
   Result=SUCCESS(0)
Dec 13 14:23:07.591: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=6001, Called Number=6001, Peer Info Type=DIALPEER_INFO_SPEECH
Dec 13 14:23:07.595: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 13 14:23:07.595: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=6001, Expanded String=6001, Calling Number=6001T
Dec 13 14:23:07.595: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:23:07.595: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Dec 13 14:23:07.595: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6001, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=6001
Dec 13 14:23:07.595: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Dial String=, Expanded String=, Calling Number=6001T
   Result=-1
Dec 13 14:23:07.595: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=6001
   Result=Success(0); Incoming Dial-peer=6001 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=6001
Dec 13 14:23:07.595: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
   Result=-1
   Result=SUCCESS(0)
Dec 13 14:23:07.595: //-1/EBBF6FC38182/DPM/dpMatchPeersCore:
Dec 13 14:23:07.595: //-1/EBBF6FC38182/DPM/dpMatchCore:
Dec 13 14:23:07.595: //-1/EBBF6FC38182/DPM/MatchNextPeer:
Dec 13 14:23:07.595: //-1/EBBF6FC38182/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Dec 13 14:23:07.615: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=7248806682, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=7248806682
Dec 13 14:23:07.615: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=7248806682, Expanded String=7248806682, Calling Number=
Dec 13 14:23:07.615: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:23:07.615: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Dec 13 14:23:07.615: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec 13 14:23:07.615: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Result=-1
Dec 13 14:23:07.615: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Dec 13 14:23:07.615: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec 13 14:23:07.631: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 13 14:23:07.631: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dec 13 14:23:07.631: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:23:07.635: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 13 14:23:07.635: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Dec 13 14:23:07.635: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec 13 14:23:07.635: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec 13 14:23:07.635: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec 13 14:23:07.635: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Dec 13 14:23:07.635: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:23:07.635: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec 13 14:23:07.639: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec 13 14:23:07.639: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Dec 13 14:23:07.639: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec 13 14:23:07.639: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:23:07.639: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec 13 14:23:07.739: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec 13 14:23:07.739: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec 13 14:23:07.739: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec 13 14:23:07.739: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Dec 13 14:23:07.739: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:23:07.739: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec 13 14:23:24.711: //-1/EBBF6FC38182/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=112, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=112
Dec 13 14:23:24.711: //-1/EBBF6FC38182/DPM/dpMatchCore:
   Dial String=112, Expanded String=112, Calling Number=
Dec 13 14:23:24.711: //-1/EBBF6FC38182/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=20003 Is Matched
Dec 13 14:23:24.711: //-1/EBBF6FC38182/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=20003
Dec 13 14:23:24.711: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 13 14:23:24.711: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dec 13 14:23:24.711: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:23:24.711: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Dec 13 14:23:24.715: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 13 14:23:24.715: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
Dec 13 14:23:24.715: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dec 13 14:23:24.715: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:23:24.715: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Dec 13 14:23:24.715: //-1/EBBF6FC38182/DPM/dpMatchPeersCore:
Dec 13 14:23:24.715: //-1/EBBF6FC38182/DPM/dpMatchCore:
Dec 13 14:23:24.715: //-1/EBBF6FC38182/DPM/MatchNextPeer:
Dec 13 14:23:24.715: //-1/EBBF6FC38182/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Dec 13 14:24:00.383: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=112, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=112
Dec 13 14:24:00.383: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec 13 14:24:00.383: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=112T
   Result=-1
Dec 13 14:24:00.383: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=112
Dec 13 14:24:00.383: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=20003 Is Matched
   Result=NO_MATCH(-1) After All Match Rules Attempt
Dec 13 14:24:00.383: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec 13 14:24:00.383: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 13 14:24:00.383: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Dec 13 14:24:00.383: //-1/EBBF6FC38182/DPM/dpMatchPeersCore:
Dec 13 14:24:00.383: //-1/EBBF6FC38182/DPM/dpMatchCore:
Dec 13 14:24:00.383: //-1/EBBF6FC38182/DPM/MatchNextPeer:
Dec 13 14:24:00.387: //-1/EBBF6FC38182/DPM/dpMatchPeersCore:
Dec 13 14:24:00.387: //-1/EBBF6FC38182/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Dec 13 14:24:00.387: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 13 14:24:00.387: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dec 13 14:24:00.391: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:24:00.391: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 13 14:24:00.391: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Dec 13 14:24:00.403: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 13 14:24:00.403: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dec 13 14:24:00.403: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:24:00.403: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
   Result=SUCCESS(0)
Dec 13 14:24:08.387: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=112$, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=112$
Dec 13 14:24:08.387: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec 13 14:24:08.387: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=112$T
   Result=-1
Dec 13 14:24:08.387: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=112$
   Result=-1
Dec 13 14:24:08.387: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
   Calling Number=, Called Number=, Voice-Interface=0x0,
Dec 13 14:24:08.391: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec 13 14:24:08.391: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec 13 14:24:08.391: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec 13 14:24:08.391: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Dec 13 14:24:08.391: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec 13 14:24:08.391: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
1 REPLY
Community Member
Hello Gelenn,
Not sure if you still have this issue. If yes then can you please share the call-flow?
242
