08-23-2010 01:19 AM - edited 03-16-2019 12:25 AM
Hi everybody
I have a scenario where i have two cluster.
Cluster # 1 . 2 CUCM's : 1 Publisher and 2nd is Subscriber. Subnet:10.4.6.0 /24
Cluster # 2. 2 CUCM's : 1 Publisher and 2nd is Subscriber. Subnet 10.4.7.0 /24
Both clusters are connected to the same Switch. I want to enable call between both the servers using 4 digit ext's.
Both ther server users can talk each other using 4 digits mean ip phones connected to the Cluster 1 serveres can call to the ip phones connected to the second Cluster server.
Waiting for a favourable reply.
Jamil Hussain
Solved! Go to Solution.
08-23-2010 01:34 AM
Hi Jamil,
You can use inter-cluster trunks (gatekeeper or non-gatekeepr controlled) or you can use SIP trunks between the clusters. Below is a link to setup doc for inter-cluster trunks (non-gatekeeper controlled).
faculty.valenciacc.edu/wyousif/VoIP/Labs/Inter-Cluster.doc
08-23-2010 06:44 AM
Just to add something, if you have overlapping dial plans then just 4 digit dialing won't be possible and you'll need to add another digit as site-code for this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
08-23-2010 01:34 AM
Hi Jamil,
08-23-2010 06:44 AM
java
