Call Manager database access is very slow
hello,
i have call manager 4.1(3)SR6, when i try to do some searchs at at the device menu the search take long time to return result and also when i apply some configuration like deactivation of froward, it doesn't applied immediately and the fucntionality remains activated after few seconds.
I have supposed that the access to the Sql Server is very slow.What do you think ?
Re: Call Manager database access is very slow
hello,
i'm always waiting for your feed-back.
Thanks at advance
Bronze
Did you check on your server if it has enough memory, Did you try to run DBhelper to see if there is any issues. Is your hosts and lmhosts files are configured properly with servers name and ip addresses.
cheers
Ikram
hello,
thanks for your reply.
I have tried to run the DBhelper yet.
i suppose that the DNS work properly, but i will verify.
One question about DBHelper, how can i check if we have any issues ?
regarding
Bronze
What is the delay between sub and pub? Also, check of sql enterprise replication monitor if there is any issues.
cheers
ikram
HEllo,
i have checked via DBhelper, but it seems good because i have good keyword displayed under DBconnection coloumn.
does this happen directly on the server???
or if you open ccmadmin from a remote computer??
java
if this helps, please rate
java
www.cisco.com/go/pdi
Bronze
May be worthwhile trying reload the server after hours to fix any memory related issues. When was the last time server rebooted. Normally, Cisco recommands once per month reboot of IPT Servers.
Cheers
Ikram
hello,
The access is slow when i go directly to the publisher, but the subscriber work correctly.
how can troubleshoot this ?
hello,
i'm waiting for your feed-back
hello,
have you any updates regarding this issue.
220
