Call Manager Database error
rohanpatel
I am having this error on Call Manager, "Database communication error". I followed the instructions on cisco and fixed the issue and now it has happened again.
This twice in 2 days... I am rebooting the PUB which will fix it, but I need a permanent fix.
Any help...
6 Replies 6
What version of CUCM are you using?
Call Manager 7.1.5
As if you have already done all those troubleshooting and didn't get rid of this, better open a TAC case. I faced the same issue earlier while changing the password and didn't follow the right procedures, but I hope you haven't done the same.
Hello Rohan,
were you able o solve this?
We are with the same issue.
Thank you in advance!
Best regards,
Norberto
Same issue here - reboots repair the error temporarily but within a day or two we're unable to login to the Pub again.  Database replication status shows 2/3/3/3/3.
CUCM 7.1.3
Leonardo Santana
Hello see if this doc helps you!
https://supportforums.cisco.com/docs/DOC-13672
Leonardo Santana
*** Rate All Helpful Responses***
