Call Manager Device Profile - Change Product Type
Does anyone know if you can change the product type in the device profile once it has been created.
Example: Profile was a 7960 now we want to migrate the profile to a 7962.
  • IP Telephony
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi,I don't see an option to
I don't see an option to do so, however you can check the 'Extension Mobility Equivalency' feature as it is quite useful in such scenarios:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsgd-861-cm/fsem.html#wp1386088
Cisco Extension Mobility (EM) equivalency eliminates the phone-model dependency of phone button templates. The following factors determine the model equivalency among the various phones:
Various features that the phone models support
Number of buttons that the phone models support
EM equivalency supports these features for the Cisco Unified IP Phones:
Feature Safe on Phone Button Template—Phones can use any phone button template that has the same number of line buttons that the phone model supports.
Size Safe on Phone Button Template—This feature allows the user to use any phone button template that is configured on the system.
Cisco Unified Communications Manager enhances the existing Extension Mobility (EM) equivalency mechanism to work across phone types as follows:
Feature Safe on Phone Button Template—For both SCCP and SIP protocols, the following Cisco Unified IP Phone models support the Feature Safe feature: 7931, 7941, 7941G-GE, 7942, 7945, 7961G-GE, 7962, 7965, 7975. For the SIP protocol only, the following Cisco Unified IP Phone models support the Feature Safe feature: 8961, 9951, 9971.
Note Be aware that the Feature Safe on Phone Button Template feature does not support using an EM profile that is configured for a newer model on the Cisco Unified IP Phone 7960 or 7940.
Size Safe on Phone Button Template—For both SCCP and SIP protocols, the following Cisco Unified IP Phone models support the Size Safe feature: 7906, 7911, 7931, 7941, 7941G-GE, 7942, 7945, 7961, 7961G-GE, 7962, 7965, 7975.
Manish
Manish
Hall of Fame Super Silver
Manish is correct (+5), no
Manish is correct (+5), no way to change the model just like there is no way to change phone model, you would need to delete and redo.
Chris
1988
