Call Manager Device reporting
Is there anyway of identifying users who own both physical phones (796X) and CIPC's, other than searching under Route plan report > Directory numbers
thus locating all devices associated to 1 DN ? It could mean sifting through hundreds of records, must be a simpler way ?
No native reporting for that, you would need to go down the sql query path for that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: Call Manager Device reporting
Hi.
What about exporting all phone detail per phone model using bulk tool and merging them into an excel spreadsheet and filtering by dn or whatever?
Hth
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo
Tried pulling off a Route plan report, however it keeps timing out when trying to open in excel via view file in>GO  tab           (I have approx 30,000 records )
Any ideas why ?
Hi Ammar.
I suggested you an export through Bulk administration Tool of all phones so that you can see the association between Device User and Extension.
No idea about timeout exporting route plan report in excel
Carlo
162
