Call Manager DIsk Utilization - 5.1x
cplatt01
Can anyone explain why, on a new install with no phones configured, the diskspace says it is 93% on the active partition? Is this standard
Jaime Valencia
most of the disk space is already pre-allocated and that disk usage is normal. you get all the linux partitions, the OS, the CUCM and all the services, the informix DBs and engine, etc.
javalenc
if this helps, please rate
java
