Call Manager Enet Interfaces
Hello All,
Call Manager on MC7845 have two ethernet interfaces.
How does both work? Active/Standby , Load Balanced / Etherchannel.
Can one have 1gb speed and the other 100Mpbs.
Many thaks
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Call Manager Enet Interfaces
Should not be changed, it is the best way for redundancy so you can connect to two switches.
Which CM version ?
Sorry. Using CM 6 and planning CM 7.
I have found the command "set network failover enable" that makes a team between enets interfaces in a active/standby configuration, migrating the licensed mac from one interface to the other in a failover. But, do not know if this behaviour or configuration can be changed.
139
