Call Manager Express CLID presentation
I have the following scenario:
IP Phones --> CUCME/ Gateway --> SIP Server.
When make an outgoing call to the SIP Server (i.e. 60123456789, access code: 6), I need to strip the access code and add a prefix (90296). The call takes place and is established with no problem, however, the screen of the phone is showing: 902960123456789 (for this example). Is there any way to avoid this behavior? (the IP phone's screen shows only 60123456789). This is a Call Manager Express scenario, I am aware that it is possible in Call Manager (CUCM), but I haven't found a way to do this with CUCM Express. All the digit manipulation is done with translation rules/profiles (since it is a VoIP dial peer).
Here is the dial-peers, translation rules/profiles and the telephony-service configuration:
voice service voip
gcid
clid network-provided
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  rel1xx disable
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice translation-rule 1
rule 1 /^6\(55........\)/ /90296\1/
rule 2 /^6\([1-9].......\)/ /9029655\1/
rule 3 /^6/ /90296/
voice translation-rule 2
rule 1 /^5555/ /1000/
voice translation-rule 3
rule 1 /^79.../ /8888/
voice translation-profile 1
translate calling 1
voice translation-profile 2
voice translation-profile PRUEBA1
translate calling 3
translate called 2
voice translation-profile SALIDA
translate called 1
sccp local FastEthernet0/0
sccp ccm 192.168.1.1 identifier 1 priority 1 version 3.1
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate profile 2 register XCODER
associate profile 1 register CONFERENCE
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 1
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
dial-peer cor custom
name local
name celdf
name celnac
name nacional
name inter
name 01800
name 01900
dial-peer cor list localcall
member local
dial-peer cor list celfull
member local
member celdf
member celnac
member 01800
dial-peer cor list celdfcall
member celdf
dial-peer cor list celnaccall
member celdf
member celnac
dial-peer cor list ldmexcall
member nacional
dial-peer cor list ldmundialcall
member inter
dial-peer cor list 800call
member 01800
dial-peer cor list 900call
member 01900
dial-peer cor list locales
member local
member 01800
dial-peer cor list celnaclocal
member local
member celdf
member celnac
member 01800
dial-peer cor list fullaccess
member local
member celdf
member celnac
member nacional
member inter
member 01800
member 01900
dial-peer voice 1 pots
translation-profile outgoing 1
incoming called-number .
direct-inward-dial
dial-peer voice 702 voip
corlist outgoing celdfcall
translation-profile outgoing SALIDA
destination-pattern 604455........$
session protocol sipv2
session target ipv4:172.25.0.42
dtmf-relay rtp-nte
no vad
dial-peer voice 703 voip
corlist outgoing celnaccall
destination-pattern 6045..........$
dtmf-relay rtp-nte
no vad
dial-peer voice 704 voip
corlist outgoing ldmexcall
destination-pattern 601..........$
dtmf-relay rtp-nte
no vad
dial-peer voice 705 voip
corlist outgoing 800call
destination-pattern 601800T
dtmf-relay rtp-nte
no vad
dial-peer voice 706 voip
corlist outgoing 900call
destination-pattern 601900T
dtmf-relay rtp-nte
no vad
dial-peer voice 600 voip
corlist outgoing ldmundialcall
destination-pattern 6T
incoming called-number 6T
dtmf-relay rtp-nte
no vad
dial-peer voice 701 voip
corlist outgoing localcall
destination-pattern 6[1-9].......$
dtmf-relay rtp-nte
no vad
dial-peer voice 900 voip
translation-profile outgoing PRUEBA1
destination-pattern 5555
session target ipv4:10.10.10.10
dtmf-relay rtp-nte
no vad
dial-peer voice 901 voip
destination-pattern 1000
dtmf-relay rtp-nte
codec g711ulaw
no vad
num-exp 7777 79101
gateway
timer receive-rtp 1200
sip-ua
no remote-party-id
sip-server ipv4:10.10.10.10
gatekeeper
shutdown
telephony-service
sdspfarm units 5
sdspfarm tag 1 CONFERENCE
sdspfarm tag 2 XCODER
no auto-reg-ephone
codec g722-64
max-ephones 5
max-dn 10
ip source-address 192.168.1.1 port 2000
calling-number local
service phone g722CodecSupport 0
system message Prueba CUCME Telefonica
load 7960-7940 P00308000500.loads
max-conferences 8 gain -6
call-forward system redirecting-expanded
transfer-system full-blind
directory last-name-first
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 79101
pickup-group 5509
name Victor Ortega
call-forward busy 79104
corlist incoming locales
ephone-dn  2  dual-line
number 79102
pickup-group 5509
label Jose Ramos
name Jose Ramos
corlist incoming celnaclocal
ephone-dn  3  dual-line
number 79104
pickup-group 5510
label IP COMMUNICATOR
name IP COMMUNICATOR
call-forward busy 79101
call-forward noan 79101 timeout 5
corlist incoming fullaccess
ephone-dn  4  dual-line
number 79103
pickup-group 5510
name Prueba 3
corlist incoming celfull
ephone-dn  8
number 4444
park-slot
name ParkNumber
ephone  1
device-security-mode none
mac-address 0009.B7AA.2062
button  1:1
ephone  2
description Jose Ramos
mac-address 0015.2B48.46C4
type 7960
button  1:2
ephone  3
description IP COMM
mac-address 001C.2339.8AE8
codec g722-64
type CIPC
button  1:3
ephone  4
mac-address 000F.24C6.AC60
button  1:4
Some of the commands applied to the configuration are only for testing purposes, but none of them worked, and the COR configuration has nothing to do with the problem, but it is included anyway.
Any help is more than welcome. Please let me know if you have any doubts.
Thanks in advance.
1001
