01-18-2010 10:16 AM - edited 03-15-2019 09:06 PM
I can not seen to get the application to assisiate for conferencing. I have posted the config and am woundering why it is not working? I can not configure the maximum sessions under the dspfarm profile 1 conference, it only gives me the option of 0.
Solved! Go to Solution.
01-18-2010 10:58 AM
A sh run is not enough, you would need to provide a sh diag to see what HW you have.
My bet is on you not having enough DSPs.
You need a WHOLE DSP for conferencing, that means 16 available channels. In case you're using a PVDM8 the "WHOLE" half DSP.
Look at what HW you have and how many DSP channels you're using already, if you don't have 16 free, options are:
A) Add more DSPs
B) Free resources
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-18-2010 10:58 AM
A) Add more DSPs
B) Free resources
java
01-18-2010 11:24 AM
Thank you for the quick reply. I do not have enough DSP resources, I only have PVDM16.
