09-10-2008 02:43 AM - edited 03-15-2019 01:09 PM
Hi all,
Can I download call manager express through the cisco website? I have download access to everything and thought this was available for download for testing?
Jamie
09-10-2008 02:57 AM
Jamie,
Yes you can. CME is built into the IOS, so depending on which version of CME you are looking for, just download the corresponding IOS version. CME 7.0 is the latest version, and is available in IOS version 12.4(20)T. Here is the version matrix:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Hope this helps.
Michael.
09-10-2008 02:59 AM
Yes I have downloaded this, I thought I had just downloaded an update.
How do I go about installing it? their is no iso or anything similair.
Jamie
09-10-2008 03:03 AM
Jaime,
If you have downloaded the IOS with voice feature set, the good news is there is nothing further to install. CME feature is in the code. Your next step is to configure CME on the router. For that, reference the configuration guide below:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
Hope this helps.
Michael.
09-10-2008 03:13 AM
Ok thanks,
I didn't realise this was installed on the router itself, I thought it was a cut down version of a server based call manager.
Thanks for your help
09-10-2008 03:15 AM
You're welcome Jamie,
Let us know if you run into any issues with your configurations.
Cheers.
Michael.
09-10-2008 03:20 AM
Thanks, one last question.
Does the GUI represent that of a cucm?
09-10-2008 03:26 AM
Jamie,
The CME gui is different from the CUCM gui. The two are very different applications whose similarity ends at their shared names.
Here's what the CME gui looks like:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/gui/user/guide/cmegui_user.pdf
Michael.
