Community Member
Call Manager fallback
Hi boys
I have a Call Manager 4.2 installed in my server, at my site remote i have Cisco SRST for redundance. Before my link MPLS is down and up any ip phones is registred from SRST Router and dont registred iny my Call Manager server. How i can to do for resolution this case?
Thank you
Community Member
Re: Call Manager fallback
Can u paste configuration from your SRST gateway.
Iftikhar Ahmed
Community Member
Below the configuration the SRST gateway:
call-manager-fallback
secondary-dialtone 0
max-conferences 4 gain -6
transfer-system full-consult
limit-dn 7940 1
limit-dn 7960 1
ip source-address 10.149.192.1 port 2000
max-ephones 40
max-dn 40
system message primary Operando em Fallback
system message secondary Operando em Fallback
transfer-pattern .....
default-destination 4400
time-format 24
date-format dd-mm-yy
Thank you
Community Member
I think configuring "keepalive" will solve your issue.
Try it.
Iftikhar Ahmed
Hall of Fame Super Silver
By default the phone will wait 120 seconds before attempting to re-registed with CM, how long did you wait? This timer is controled by the device pool the phone is assigned to.
Chris
Community Member
I configured now the keepalive for 1000 seconds, but the phone dont registrated at Call Manager 4.2 only no fallback.
Community Member
I enable the logging and receive the log:
CM-aborted-TCP
*Nov 15 08:45:39: ephone-15[46][SEP000F24AAA3F2]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:45:39: ephone-15[46]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:45:39: ephone-20[16][SEP0015638ACA48]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:45:39: ephone-20[16]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:45:39: ephone-21[13][SEP0013C44A6B2F]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:45:39: ephone-21[13]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:45:39: ephone-22[23][SEP000F23C48DD9]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:45:39: ephone-22[23]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:45:39: ephone-23[45][SEP000F23C48789]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:45:39: ephone-23[45]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:45:39: ephone-24[47][SEP00115C98BC2E]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:45:39: ephone-24[47]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:45:39: ephone-25[12][SEP000F24AAA4A8]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:45:39: ephone-25[12]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:45:39: ephone-26[43][SEP0013C44969C9]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:45:39: ephone-26[43]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:45:39: ephone-27[38][SEP000F23C48859]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:45:39: ephone-27[38]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:45:39: ephone-29[22][SEP0015C617CFAB]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:45:39: ephone-29[22]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:46:09: ephone-3[54][SEP000E3892DFFD]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:46:09: ephone-3[54]:SkinnyCheckPendingCallBackPhone scan 2 lines
*Nov 15 08:46:09: ephone-9[4][SEP000F23AD7C3A]:CallPrompt line 0 ref 0: Operando em Fallback
*Nov 15 08:46:09: ephone-9[4]:SkinnyCheckPendingCallBackPhone scan 2 lines
425
