Call Manager Integration with PABX
Hi All,
I have a Call Mnager 4.2 intalled and i also have ERICSSON MD110 PABX installed.
I want to integrate both.
Could you please help on additional hardware (card) neede and the configuration guide.
1 REPLY
Silver
Re: Call Manager Integration with PABX
CCM intergration with Ericsson MD110 PABX: I Looked up on Ericsson pbx datasheet. It says there is a parameter for Make call party characeristics for your switch. 00= no notification is given to party 1 when call is made. 01=notification such as ringback or busy signal is given when call is made. You may want to check into this.
Change the 6th bit in the VARC (ringback to cooperating exchange) has to be set to 1(MD 110(BC9)).
You can direct integration between MD110 and CUCM 5.0 via H323. And H323 on the MD110 supports limited features when
integrated to CUCM.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/5_0/pbx_int/519719nt.pdf
289
