Call manager internal logic
All,
I just started to read on call manager and get confused with calling search space, partitions, route patterns, route lists........
Is there a good reference there on how they interact and how call manager works?
Thanks!
1 ACCEPTED SOLUTION
Re: Call manager internal logic
Yes, the SRND
Dial Plan
I'd recommend you to read the whole chapter.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
Yes, the SRND
Dial Plan
java
java
147
