What is the integration between the Clusters? Are you using Intrcluster Trunk?
It could be either cluster configuration issue, first on your cluster ensure that the CSS applied to the Trunk has access to the phone paritions, and that expected number of digits matches significant digits configuration on the trunk.
On the Singapore trunk ensure that they have a route pattern pointing to the ICT and that phones o n that cluster can reach this route pattern.
Chris
