Community Member
Call manager issue.
 In my VOIP design i have 1 pub with 4 subscriber and 1 MOH server in the cluster. These nodes are geographically located with clustering over wan architecture. I am using CUCM 8.5.1400. I hev 5 cluster configured as mentioned above.
         1. Here i can ping SUB- C form Network PC , Publisher of cluster -1 and vice versa.
         2. But " utils network connectivity test " FAILED and SUB-C of Cluster on not able to send/receive any UDP packets.
         3. Because of this:
                                      a) Phones registered to this subscriber is visible as "UNREGISTRED" in PUB.
                                      b) But are registred to SUB-C of cluster 1.
         4. Now by dialing a DN registred to SUB-C of cluster 1 form cluster one I am able to dial 90% of the DN's.
         5. But not able to make INTER-CLUSTER call from DN's registered in SUB-C.
  please explain.
1 ACCEPTED SOLUTION
Hi Rohit,In such cases i
Hi Rohit,
In such cases i would first start by checking the replication status on all the nodes in the cluster and make sure it is 2 on all of them. Once it is fixed, then each issue needs to be tackled one by one, like the call drop issue or the phones showing unregistered issue.
https://supportforums.cisco.com/document/52421/troubleshooting-cucm-database-replication-linux-appliance-model
Manish
1 REPLY
Hi Rohit,
Manish
44
