Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Call Manager on approved server
Hi All,
I am new entrant to cisco voip solution. I bought a cisco approved HP server and call manager 4.3 DVD pack (which has more than 20 dvd's). And firstly started with hardware detection dvd, i have read forums and blog usually it fails and gives an error if the part number of the server doesn't matches but in my case it went smooth and nice there was no problem on it. after completing it asked for ip address, computer name,product key, workgroup and timezone. After that it created some image and showed a display "insert dvd install OS_DVD 3 and it will continue automatically" but i tried with all the DVD that came with the call manager 4.3 package but none of them works and didn't continue the installation.
Any one have suggestion on this..
Thanks inadvance.
Green
Re: Call Manager on approved server
Which server model?
Which OS exact version you are installing?
Thanks for your reply.
I am using HP DL 380 G3 dual xeon processor with 4 gigs of ram and 6 hot swappable HDD. server with the part number 310587-001. And the call manager dvd pack came with 2003 server. Please advise
99
