Call Manager / Unity test plan
Has anyone taken the time to document a good test plan for a typical CM / Unity cluster. It seems I always finish up with an install and then sit and around and wonder did I do everything. I am looking for a check list of sorts that I can run through at the end of an install to make sure I have done everything...MoH , Conf , MWI etc etc
thanks,
Matt
Re: Call Manager / Unity test plan
Maintenance Checklists for Cisco Unity Integrations
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/maintenance/integ_checklist/5xcuinteg_chklst.html
about checking that all is set for CUCM / unity, i'd recommend to read carefully the integration guides.
java
if this helps, please rate
java
www.cisco.com/go/pdi
VIP Super Bronze
attached are some steps I have used recently for a new install.
You may need to adjust the formating as this was in pdf, I just copied and pasted some details in word to get you going..
All the best
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
2019
