Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Call Manager Upgrade question
Good day, Gents,
Want to ask what can be advantages if I upgrade Call Manager software
from 4.1.3 sr 4d
to 4.2.3 sr 2
Are these advantages can be essential or not ?
Does it make sense ?
I mean is this a fritterware ?
Thank you.
2 ACCEPTED SOLUTIONS
Re: Call Manager Upgrade question
It really depends on your needs. Here are the new capabilities that CCM 4.2(3) has:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_2/rel_note/423cmrn.pdf
Keep in mind that if you upgrade to CCM 4.2(3) you won't be able to upgrade to CCM 5 since is not on the compatibility matrix:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/ccmcomp.htm
Hall of Fame Super Red
Hi Tobivan,
Just to add a note to Jorg's great info (5 points for your continued good work Jorg) This upgrade is certainly not essential. The 4.2 release does add some really great features (marked with **) If you do not have the need for these changed/added features I wouldn't upgrade to CCM 4.2. It sounds like soon to be released CCM 6.0 might be worth waiting for.
New and Changed Information for Cisco CallManager Features CCM 4.2
The following sections describe new and changed information related to Cisco CallManager features:
Multilevel Precedence and Preemption Enhancements
Device Mobility
Cisco CallManager Attendant Console and Call Pickup Limitation
** Call Pickup Notification
** Directed Call Park
IPMA Enhancements
Cisco Messaging Interface Enhancements
Call Forwarding Enhancements
Password Management Features
** Log Out of Hunt Groups
** Voice-Mail-Related Changes to Hunt List and Hunt Pilot
New MLPP Service Lockout Enterprise Parameter
Phone Button Template
Call Diagnostics and Voice Quality Metrics
Overlap Sending and Receiving for H.323 Gateways
SDL Traces
Cisco CallManager T1 CAS Hookflash Transfer Support
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a00805f1470.html#wp2430214
Hope this helps!
Rob
Hi Tobivan,
Device Mobility
IPMA Enhancements
SDL Traces
From this doc;
Hope this helps!
Rob
Thank you, Gentlemens.
125
