Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Call Monitor with Supervisor Agent
We are monitoring our agents calls from time to time and everything was working up until yesterday when we swapped their 7960 phones out and gave them 7965 phones. Now you get a error message from the supervisor desktop and can no longer monitor their conversations. The agents (desktop agent) works fine.
I know 7965 phones are supported (at least Cisco says they are), we also resynced jtapi through the UCC Express interface as well as associated the new phones with jtapi via Call Manager.
The only thing not working is the recording feature.  Any ideas?
Thanks!
1 ACCEPTED SOLUTION
Super Bronze
Re: Call Monitor with Supervisor Agent
On the CCMAdmin phone configuration page, ensure that 'Span To PC Port' is enabled. Default is that RTP cannot be seen by the agent PC, so desktop monitoring won't work.
Also check the 'Advertise G722' is disabled, as this isn't supported by desktop monitoring or sniff based recording.
And don't forget to reset the phone afterwards
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
awesome!  Works like a charm!
thanks!!
267
